It is currently Tue Aug 12, 2025 7:41 am
Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2
PostPosted: Fri Mar 04, 2016 9:15 pm
Last Name: Shaw
City: Philadelphia
State: PA
Zip/Postal Code: 19125
Ridgid, Ryobi, Milwaukee and many harbor freight power tools all made by the same company. TTI
Sent from my HTC Desire 626s using Tapatalk
Another day, another dollar.
PostPosted: Sat Mar 05, 2016 2:40 am
James Orr wrote:
What is it about the micro-adjust that you like?
It actually works!
These users thanked the author Pmaj7 for the post: James Orr (Sat Mar 05, 2016 9:51 am)
PostPosted: Mon Mar 07, 2016 8:20 pm
Here's the new jig with the router installed. Gonna cut some binding channels tonight.
These users thanked the author Rod True for the post: James Orr (Tue Mar 08, 2016 10:54 am)
PostPosted: Mon Mar 07, 2016 8:48 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
I have the same router in my binding jig. Your binding jig looks MUCH nicer than mine, Rod! I'll likely buy a few more of the Rigid when they go on sale for $99.
Alex
PostPosted: Mon Mar 07, 2016 8:58 pm
Alex that's the Canadian Luthier Supply jig. I'm pretty sure after a few different styles over the years (including my own version of the above) I'll stick with this version.
And I'm with you regarding the router, I was hoping that HD would put it on sale for March but I needed it sooner and I'm sure it's still worth the extra $50.
PostPosted: Mon Mar 07, 2016 10:10 pm
I've got the earlier model of this jig made by Mark Kett. At the time I bought a $90 router from Sears, similar in size and weight to that Ryobi, and it's never left the jig. Seems like overkill at first, but the jig can easily handle the weight. And even though this set up works fine, I don't think you'll regret the extra $$ for the luxury of a smooth height adjustment.
And just so you know when the time comes to replace the router bit, CMT makes a cutter this size without a bearing that needs to be cut off, and with the blades set at a shear angle - so the blades are set to also slice, and not just hammer away at the wood. Well worth the money.
PostPosted: Mon Mar 07, 2016 10:30 pm
State: ON
I will have to look into the CMT cutters. And to clarify, the cutters I've always included with this jig do have the shear angle you describe. It may not be clear in the picture, but it is there.
Josh House
http://www.houseguitars.com
PostPosted: Mon Mar 07, 2016 10:35 pm
Yup, I concur. That bit has a sheer angle set to it. Most good tools houses will have a 1-1/4" rabbet bit.
